It sounds like your media is malfunctioning (controller issue).
Our company, LC Technology, is the only Sandisk-approved
data recovery company and we have been working on their products
for over 5 years. You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Sandisk with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
ericb@lc-tech.com
1-866-603-2195 ext 103
LC Technology International
Apadill77
I have seen this with my 2 that I have. Normally it happens it the thumb drive thinks it did not get properly unplugged from my computer. Normally all I have to do is unplug it and plug it back in an it connects just fine.
If this does not work for you there may be a problem with the USB port. So I would try you thumb drive on another computer using one of the ports that acutally are on the motherboard. If it works then go back and try it again on your computer USB Ports that are connected to the motherboard. If it works again they you have a problem with your front USB and you may need to stop using them on this computer. I have seen this from time to time where something with happen to the front USB where it with not work properly. It could be a problem with the port or/and the connection back to the motherboard.
Hope this helps
Issken
what OS are you using? will the device work in another pc or usb drive on the same pc?
