SOURCE: Programming the Acquos Remote
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
SOURCE: Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
SOURCE: No Audio on Sharp LC-32d43u
If you had sound for before and then lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
SOURCE: Remote function on LC-32SB21U stopped
This is a common problem with Sharp LCD models. This seems to be a faulty IR circuit. A simple solution that sharp gave to their customers - unplug the TV for few minutes, say 15 minutes and then plug it in. Most of the times it would work.This is more of a design fault as there is a problem with IR circuit that somehow freezes and needs a reboot. They have certain upgraded firmwares for the same. It could be due to faulty IR sensor ( though rare possibility ).Unfortunately, this is not a DIY and you need to call Sharp.
Note - This is a common problem and Sharp is aware. Calling a local tech would not help as this has to be taken care ONLY by Sharp.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
