Hi chad0872,
First and foremost, you can't do anything if you don't have all of the components needed to do the job. You will definitely need a computer. More importantly, you will also need a Micro SanDisk and TransFlash to SanDisk adapter. The Micro SanDisk is a very small device, approximately the size of a chip. The disk is placed in your phone to store your phone's items for transfer. The TransFlash to SanDisk adapter is used to access the SanDisk files on your computer. Your SanDisk should be at least 256MB for sufficient storage space.
Once you've established and obtained everything you need, you can now begin the initial transfer process. Insert your Micro SanDisk into the phone where your ringtones are stored. Access the Media Folder or Content Management folder in the phone. Highlight each ringtone file you want to transfer. Open the Options' section available for the ringtones and opt to move your ringtones from the phone's storage to the memory card. Once the transfer process is complete, remove the memory card from the phone
Now that you have moved your ringtones to the Micro SanDisk, place the Micro SanDisk into the TransFlash SanDisk. Insert the TransFlash SanDisk into your computer. This expandable memory slot can usually be found in the from of most laptops and next to the USB slots on the front panel of desktop model computers. Once the insertion is detected, your computer's AutoPlay dialog window will appear or an import options will be given. When the ringtones' window opens, drag and drop the ringtone files from your Micro SanDisk to your computer's desktop screen.Then transfer it to your phone,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
