LG WM2277H Front Load Washer Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error codes - LG WM2277H Front Load Washer
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on Mar 15, 2010
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
11051790
Points
101587
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Dan Webster
Level 3:
  • LG Master 8,221 Answers
  • Posted on Mar 17, 2010
Dan Webster
LG Master
Level 3:
Answers
8221
Questions
5
Helped
2573604
Points
25840
2277
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
A
Anonymous
What is the exact error code you are receiving on your LG WM2277H front load washer?
  • Anonymous Mar 15, 2010
    error codes? Not enough detail. Please describe your question better before asking it, this will save us both time. Thank you for using Fixya
Top LG Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
