SOURCE: I have an F7 error code
This usually indicates a stuck key, requiring keypad replacement.
This often involves replacing whole console assembly. You need full model a and serial to order parts.
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
SOURCE: GE Profile F7 Error Code
I'm not sure what your problem is, but I have the same one. My stainless steel glass top model ?? is beeping all the time with error f7 on all the 4 tem control readouts. I'm guessing this is your problem as well. By turning the temp knobs it will stop, but sometimes restarts later for no reason. Other sites mention a ribbon cable on the touch controls (if yours has it, mine does ) that must be cleaned with rubbing alcohol. You turn off the power, and after unlocking the cable you clean the contacts with an easer and a q-tip w/rubbing alcohol. I don't know if this works but I might try it as the beeping is driving me crazy! The service techs will try and sell you about $450 in parts to fix the problem. This problem apparently has plagued these units for almost 10 years. Seems heat makes the cable get shorts at the contacts.
I HAVE NOT TRIED THIS YET so beware, but I had a short in my microwave and the site helped me fix a $500 control board for about 15 cents ( jumped a short on the board with a small wire!) Hope you get your problem fixed.
SOURCE: F7 error code
Easy fix: Just carefully disconnect the ribbon from the slot, get a pensil eraser and use it on both side of the contacts, slide it back in and you are set.
