I have an Oki B6200 with replace fuser E error How do I fix this? The solution already posted does not work. I do not have a "paper menu" or next button
"Paper Menu"
"System Menu"
"Factory Defaults"
"Reset Toner Life"
My printer has left right and up down buttons menu and select
Main menus are
"Print Language"
"Report/List"
"Meter Reading"
"Admin Menu"
"Display Language"
"Ready to Print"
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
It sounds like your fuser is broken, you should be able to pick one up cheap on ebay, I have had the same issue and was toying around with it 4 days then I just gave in and got a new one, error went away!
sorry I couldnt be more helpful.
Paul
SOURCE: Hello , my oki b6200 display error replace fuser
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
SOURCE: Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
SOURCE: OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
