One For All URC-4330 Remote Control Logo
Posted on Apr 09, 2010
Universal remote code Magnasonic GCT 5508 - One For All URC-4330 Remote Control
2 Related Answers
Anonymous
  • Posted on Feb 01, 2009
SOURCE: code for Magnasonic TV
I have magnasoni TV 14`` and I have Unversal remot RCA in need some help for codes thanks
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jul 05, 2009
SOURCE: Universal remote one-for-all -need code for Magnasonic DVD 816-4C
First, you have to realize that there is no 'universal' remote; the description is a fraud. Even the type of remote that can 'learn' codes from an original cannot learn from some of them (we own one like that). They are, at best, 'multibrand' or 'multidevice' remotes.
About the only chance you might have is to check the All-In-One website for an updated list but it is unlikely that all functions of your DVD will be available with that remote.
You may be forced to buy an original remote here:
Remotes
I did not, however, see one for your 816C; only 'B.'
Have a magnasonic tv GCT-5517 and 2 rca remotes a universal and system link 8av how do i get them to workmagnasonic codes
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Code pour magnasonic MTC2710
Universal remote set up code for Magnasonic TV with RCA RCR311W universal remote control is [ 1164 ]
I purchased a universal rca remote. On the back card it listed as one of the brand name tvs magnasonic which is my tv. When i got it home there was no code listed on the paper inside for my tv. I tried...
Hi Bonnie,
I understand your frustration. RCA / Thompson Consumer Electronics has made dozens of different model universal remotes control devices. Without knowing your particular model number, it's hard to give a good answer.
I found a list of RCA codes here, and some others elsewhere - but none included the Magnasonic brand TV you have. If you have gone through the code search feature of the remote without any luck, it is probably because the TV is not supported by the RCA remote control. Not every TV, VCR, DVD, etc. is supported.
You may find that you'll have to return the RCA device and obtain a Magnasonic brand remote to operate your TV. You can view Magnasonic's Customer Support page here.
Need code for a magnasonic tv
573,659,660,669,672,677.....hope this helps...
How to get RCA UniRemote to work Magnasonic DVD player
gave up; believe my DVD is non-compatible to remote use. period.
1helpful
Have all for one 4110 - need code for magnasonic
http://www.hifi-remote.com/ofaold/tvcode.html
MAGNASONIC 017,019,030,153,154,156,193,093,179
Should be one of these. If not try the website.
I cant set my universal remote to my magnasonic tv
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
2helpful
Magnasonic mctv1311 remote control code
Go to remotefinder.rca.com/default.aspx?site=rca for the correct codes (there may be more than one for each remote and try them till you find the right one).
36helpful
6answers
Code for Magnasonic TV
Top One For All Televison & Video Experts
Sudeep Chatterjee
Sudeep Chatterjee
Herb Box
Herb Box
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
