SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
SOURCE: Philips Universal Remote #CL034- Need tv codes.
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
let me know if this helps
SOURCE: zenith universal remote codes
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=zenith&dv=universalremote&md=zn501s&kw=&st=&ar=&dt=&so=&pg=2&file=others/zenith/zn501s-manual.zip
Unfortunately, there is no code sheet included in this user guide. However, Code Search is covered on page 10.
Testimonial: "thanks, took 2 minutes and i was back in action"
