Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
Posted on May 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to solve error1 problem - Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Anonymous
Level 2:
Sniper:
  • Expert 54 Answers
  • Posted on Jun 18, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
54
Questions
0
Helped
36608
Points
343
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
Machine error1 broke needle then machine come error1 can i override
Look for Error 1 in the troubleshooting section of your owner's manual or search for:
Make Model Error 1
Error-1
Hi there:
Manual says Error1 is a damaged or dirty CD. Suggests reinserting. If that doesn't work, it suggests returning to the dealer.
Hope this helps.
Went to sew on my elna 6005 machine made a growling noise and stated error1 do you know what this means? I have had the machine since it was new and never had this issue
I would suggest that you take off the needle plate and check if the bobbin holder, the black plastic bit you put the bobbin into, has become dislodged and moved out of alignment. This can happen if you have a jam up as the holder is held in place with a magnet.
Your manual should show how to remove and clean under it in the cleaning section and there is probably some thread in under it.
It should have a mark on it that needs to align with a mark on the stopper, on the right side I think, and you may find that yours have moved a little out of this alignment.
I'm hoping that this is the problem for you; as its easily solved. After you've put the holder back, just turn it off and wait a second, then switch on and hopefully it will reset. Also check the back of your manual, it should have troubleshooting at the rear which may give a diagnosis on the Error1 message.
Nothing happens escept error1 when print button is pushed
Tape jam or battery low. Please clean the printer and/or exchange the batteries.
The labeller says "Error1" when I press print. I have changed batteries. Not sure what the problem is?
Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Network occured while connecting to the server
network error1
Whis server? while connecting with what
When putting in a cd screen shows error1
Is it with all cds? Also what is the make & model this would help in tracking down your error code
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
