Heating & Cooling Logo
Posted on May 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pf code - DeLonghi Pinguino PACL90 Portable Air Conditioner
Anonymous
Level 3:
  • DeLonghi Master 43,501 Answers
  • Posted on Mar 07, 2011
Anonymous
DeLonghi Master
Level 3:
Answers
43501
Questions
0
Helped
11051790
Points
101587
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
What is a flashing PF means.
Let's guess it is a Maytag Dryer :>/
'Make model (what it is) in all questions please.
A PF (Power Failure) error code indicates that the drying cycle has been interrupted by a power failure. Touch and hold START to restart the dryer cycle or press POWER to clear the display.
Dec 14, 2019
PF - Error Code - Dryer - Product Help - Maytag
Oct 23, 2022 • Dryers
tip
<p><br /> <p>There is one<b> <i>Error Code that is almost universal to most any appliance</i></b>. The<b> PF or Power Failure code</b> is usually the same no matter what <b>type of appliance</b> or <b>brand</b> you are working with. Even with the fact that this <b>error code is so common</b>, I still see many questions on <b><i>www.Fixya.com</i></b> that are asking <b>what the PF Error Code means</b>.<br /> <p><br /> <p>So now the next question is this.<br /> <p><br /> <p>What causes the <b>appliance to give you the PF error code</b> in the first place?<br /> <p><br /> <p>The most common cause of your <b>appliance giving you the PF error code</b> is a problem with the <b>power coming in from your utility company</b>. Of course if there is an <b>interruption of power</b>, and then the power comes back on you will get the<b> PF code</b>.<br /> <p><br /> <p>Some <b>appliances will give you the PF code also if the power voltage goes low</b>, or goes into a <b>brownout</b> condition. Depending on the sensitivity of the <b>appliance control</b> you may also get the PF code for other reasons such as <b>frequency problems</b> or <b>voltage fluctuations</b> or <b>power spikes</b>.<br /> <p><br /> <p>The other <b>problems that can cause the PF error code</b> can be internal to the appliance.<br /> <p><br /> <p><b>Loose wires going to the circuit board</b> or the control can also be a <b>cause of the error code</b>. If a <b>wire terminal end</b> happens to get <b>corroded</b> or loose, the <b>vibration from the machine</b> can cause slight power problems and this can <b>cause the PF code to be displayed</b>. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by <b>banging on the side of the appliance</b> or <b>slightly moving the wiring harness</b>, to see if you can get the error code to display.<br /> <p><br /> <p>The bottom line about this <b>power failure error code,</b> is that it is <b>power related</b>. Finding the exact cause can be difficult. If you are continually having to <b>reset the appliance</b> then check to see if all of your appliances are giving the same code. This will indicate <b>utility power problems</b>. If only <b>one appliance is giving the PF code</b> then it is probably internal to the appliance.<br /> <p><br /> <p>
on Mar 06, 2011 • Refrigerators
Hey guys....My Fridgidaire Gallery dishwasher is locked closed and has pf code on it....now what?? Thank you!
Cutting the power for 5 minutes, usually releases the lock.
Your electricity voltage is too low.
Frigidaire Dishwasher Error Code = PF Check / Repair / Solution = A power failure has occurred. More than 10% of power has dropped to the unit. Check house wiring.Feb. 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To ...
How to Fix a Frigidaire Gallery Dishwasher With a PF Code ...
https://www.hunker.com > ... > Dishwashers
Step 1. Check the other appliances in your kitchen for power interruptions, as an indicator of what might have caused the "PF" error for the Frigidaire dishwasher.
FIXED - PLD2855RFC0 Frigidaire - PF Error Code ...
https://www.applianceblog.com > mainforums > threads
May 22, 2013 - I'm getting the "PF" error code at the same spot... ... Brand: Frigidaire ... verified the heating element has excellent continuity and ... What fixed it for me: I replaced the circuit breaker of the dishwasher on the outside power panel. ... When the door is closed, it gives a PF error and flashes a few times. If I open ...
Frigidaire Dishwasher Error Codes Explained
https://howtofixit.net > frigidaire-dishwasher-error-code...
Feb. 10, 2020 - This is a guide on what Frigidaire Dishwasher error codes are and what ... To fix this error code try opening and closing the dishwasher door to reset the cycle. ... When the i30 error pops up it is saying that the bottom pan has a leak to it. ... that you will run into will be power failure, this is under the PF code.
Mar 03, 2021 • Dishwashers
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
2answers
Code p1445
P1445: CHECK PF SENSOR HIGH VOLTAGE TO PCM
Continuous Memory Diagnostic Trouble Code (DTC) P1445 indicates that Self-Test has detected a PF sensor circuit input above the maximum.
Possible causes:
PF shorted to VPWR.
PF open circuit.
PWR GND open circuit.
Damaged purge flow (PF) sensor.
Damaged PCM.
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
heatman101
,./;''l
PF Code as soon as try to start dryer, you get the code when select the time
heatman101
p[[p
1helpful
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
2helpful
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Top DeLonghi Heating & Cooling Experts
Paul Carew
Sudeep Chatterjee
Sudeep Chatterjee
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
