Sharp AR-5316 Advanced Digital Imager Copier Logo
Posted on Jun 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
H2 error code - Sharp AR-5316 Advanced Digital Imager Copier
abbas rezazadeh
Level 2:
  • Expert 328 Answers
  • Posted on Aug 10, 2010
abbas rezazadeh
Expert
Level 2:
Answers
328
Questions
Helped
90214
Points
530
Error code H2-00 on a sharp copier MX-B402 how to reset?
H2 is an indicator that the temperature sensing device is reading open
How to clear error code H2-06
hi
find link for error code H2-06
https://www.youtube.com/watch?v=M6QtVDYFmlo
Toshiba 161 is error code H2
Error Code H2-00
Description: Thermistor open detection
Causes: The fusing thermistor is open.
www.electro-medical.blogspot.com
Bosch tankless water heater error h2
H2 wasnt an error code on those machines... could you check the display and ask again?
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
7helpful
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
15helpful
4answers
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
