Http://en-us-support.belkin.com/app/answers/detail/a_id/48
all routers have reset button on them, you can reset the router to the factory settings and set up yor wireless with the new code
Simply reset the router with the reset button, while removed from the power, then hook it all up again, and hook up via an Ethernet connection, and you can now enter the Router again, as default, logon & password, usually, admin.. then you can go to security, amd generate another WAP/WEP Key, when you generate it's a good idea, to copy/pate to a notepad document for later use. The save the routers settings, and reboot router. Now when you disconnect from Ethernet, and attempt to connect to the Routers WiFi & SSID, The network, it will ask you for you Network logon, simply open that notepad document and copy/paste that large Key number into the required field, and logon. Maje sure you save settings so you don't have to do it again. Do this for all PC's that wish to connect to that network.
