Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
Posted on Jun 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code on display "CE". Does this also mean the unit if not freezing while the error appears?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jun 25, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
0
Helped
71808
Points
902
Maybe theres a defect in the board causing the error or the compressor bis defective
2answers
True T-49F 55? 2 Door Solid Reach In Freezer. How to solve error code E1 on freezer Tru T49f?
Question edited for clarity.
Question moved to maker category.
Thermostat Probe Error
E1 error on a true freezer. True Freezer, 5yrs. Just
JustAnswer
https://www.justanswer.com > Appliance Repair
Mar 6, 2022 - Ok. The E1 error code indicates a thermostat probe failure.
1 answer · Top answer: Hi, welcome to JustAnswer. My name is***** am a ticketed HVAC and refrigeration technician with ...
True Refrigeration Troubleshooting
Parts Town
https://www.partstown.com > resource-center > guides
P1 Alarm/ E1 Code. What does it mean? - This indicates a thermostat probe failure. "P1" displays on units with Dixell electronic controls. "E1" .
1helpful
Replace the 9V battery in a Frigidaire Upright Freezer Model GLFU1767FW4?
Hello Kerry;
My name is Peter. I am a retired field service refrigeration technician.
You do not have a 9V battery in your unit. It is usually located on the right hand side of the bottom toe plate. There is a small door. This is just a batter backup if you loose cooling or power.
CE means Communication Error. It is like the check engine light on your car. It just tells you that there is something wrong. The 'd' means door seal. There are no sensors or electronics connected to your door seal.
1.) Is your freezer fan running?
2.) Is your lower back condenser fan running?
If they are running the problem is with your main control board. This is located behind your freezer, on the left hand side and mounted on the side wall with several screws. This is a easy part to replace.
PART NUMBER: 216979700 Cost: $134.00
There are only several connectors on the back and a main cable connector.
If you elect to do the work your self, make sure you ground yourself by touching bare metal. Static electricity will knock out a board. Needless to say before the start of work unplug your unit.
If you were to call me when I was a service tech, I would double the part cost plus at least $140.00 labor.
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
3answers
I have CE error code. Both sides of my freezer are hot
Try to check the freon or cooler on your freez. but if you confusing about the damage look the Certified Engineer to check that...
2helpful
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
My Chestfreezer is displaying FF
I believe the FF would mean a thermistor has an open circuit . If so then the sensor would need to be replaced .You can ohm the sensor and at room temp it should be around 1100 ohms.
Always disconnect power before attempting to repair any electrical appliance
Oct 21, 2017 • Freezers
1helpful
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Top Kenmore Freezers Experts
jdthefixer
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
