SOURCE: need to unlock a Grundig
Your quoted Serial Number 241008A0019580 is not in the available GRUNDIG database
Check the metal casing to see if there are any other numbers stamped in it
Grundig Serial Numbers often begin with GR ************
SOURCE: safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set
with the button ''1'', the second number of your code can be set with
button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons
the value indicated in the screen will be increased by one. So if the
first number of your code is 5 then you have to push the button ''1'' 5
times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an
actual sticker which is in the format you describe. You'll need to
remove the unit from the dashboard to be able to get access to this.
SOURCE: i need unlock code.
theres no unlockcode go to manufacturer stereo might be 5 finger discount keep it legal
SOURCE: grundig CAR 200 (D) series radio code required.
normally on those it it is a four digit code it will be 4265
???? ?? ????? ? ???? ?? GRUNDIG CAR2002 E. ?????? ????? GM 020211324940.
