JVC GR-SXM260U Camcorder Logo
Anonymous Posted on Jul 05, 2010
E06 problem jvc gr-sxm260u - JVC GR-SXM260U Camcorder
  • Anonymous Jul 06, 2010
    @ms-shop
    can u please explain to me how i would go about doing this step by step and do i need to go to a specific website for the whole resetting prgraming ordel please help me fix my problem by giving a little direction
    thank you so much
Oloyede Monsuru
Level 3:
  • Master 1,468 Answers
  • Posted on Jul 05, 2010
Oloyede Monsuru
Master
Level 3:
Answers
1468
Questions
0
Helped
415057
Points
4012
this an indication of error detected by the sensor reader meaning that range has fail below 06degree the camcorder will need a resetting programing before you can do this you will have to put off the system for some time remove the battery if any then put it on again and then reset it the problem is solve .
please rate this solution .
thank you and thanks for using fixya.
Manual for camcorder JVC GR-SXM260U
http://books.jvc.com/booklist.asp?Model=GR-SXM260U
Nov 12, 2010 • Cameras
Please send me a manual of this item JVC gr-sxm260u
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GR-SXM260US
Need a user manual for the JVC digital camcorder model number : GR-SXM260U ; serial number 159k2192
GR-SXM260UC:
http://resources.jvc.com/Resources/00/00/95/YF016ien.pdf
GR-SXM260US:
http://books.jvc.com/Download/358947889/LYT1214-001C.pdf
1helpful
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
1helpful
What cable do I need to hook up Video camera to pc?
Try Firewire Cable ....but check that your Camcorder as well as the PC has the port ..... If not then check S-Video Cable
Instruction booklet
Hi - You can download the manual by clicking the link underlined in blue below:
GR-SXM260U
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Mode/Time Settings?
While in the record mode, try pressing the menu button (volume) to get to the SYSTEM MENU. Then in the "To System Menu or Next" columns roll down until you find the record mode and press the button to change the mode.
GR-SXM260 - which S-Video cable do I use?
I Used a standard cable and it sees to work
GR-SXM260u
2answers
E04 MESSAGE KEEPS APPERING. HOW DO I REMOVE IT AND OPEN THE DOOR
buen dia, por favor , tengo una camara jvc smx-260u, y no poseo el manual de instrucciones, podrian darme informacion acerca de este manual
mi direccion,
laguz77@yahoo.es
Top JVC Video Cameras Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
