Posted on Apr 21, 2008
Error code L4-31 on Sharp MX-2300N - Sharp Office Equipment & Supplies
5 Related Answers
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Sharp MX-2300N
throw it out, buy a Xerox
A
Anonymous
  • Posted on Jun 01, 2008
SOURCE: error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
Anonymous
  • 2120 Answers
  • Posted on Oct 11, 2008
SOURCE: I have an L4 error
L usually stands for laser problem, not good.
Try unplugging power cord for 10 seconds.
Anonymous
  • 75 Answers
  • Posted on Nov 20, 2008
SOURCE: can not delete address stored
press in 9 * 8 # 7 on key board press the start key use the # key to scroll throgh the options till clear memory is in the display press enter. this will clear ALL memory & reset it to factory settings
MCS SALES AND SERVICE
  • Posted on Dec 19, 2008
SOURCE: Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Still having the problem of F2-64 error code for sharp mx 2300n I need the solution please
For support, the User Manual, and other documentation for your MX 2300n, go here:
http://siica.sharpusa.com/product-downloads
Good luck.
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
2answers
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
2answers
How do I fix the error code 'U2-30'on my Sharp MX 2300N color copier?
please reset the machine by eject the power and data cable for a one minute and also re installer the printer driver
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp MX-2300N Maintenance Required: Code VC
Time for some scheduled maintenance! Call a local sharp dealer.
google sharp service locator, enter your model and your zip code to find a dealer near you.
Copier Collin Houston TX Copier and Imaging Expert
2answers
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
9helpful
Sharp mx-2300N printer error maintenance required code vk
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
