SOURCE: cant transfer limewire music from my computer to my mp3
The Limewire music is located in your My Computer> C:>Documents & Settings Folder>Administrators Documents (your name)>Shared Folder. You can manually drag these files from this folder onto your device, located under My Computer>Device Name (there may or may not be a music folder, you should put it in there if there is). Once you drag & drop the files, you should safely disconnect your device, then you are done. Best of Luck.
SOURCE: how to get songs onto mp3
Connect your mp3 player via usb.
Open it via My Computer.
Copy mp3 files.
Disconnect it by clicking safely remove hardware on your taskbar.
SOURCE: camnex mp3 player
I have a 1 Gig Camnex Mp3 player it comes with a disk that has a movie converter on it. put the movie through the converter. when don connect the player to the computer, mine sees it as another harddrive, and copy converted movie to unit. that's it.
SOURCE: MP3 Songs were downloaded into library but wont synch onto GoGEAR
All GoGears are completely incompatible with iTunes, AAC format.
-Tha Mp3 Doctor
