Computers & Internet Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 1275 - Computers & Internet
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on Aug 09, 2010
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
727890
Points
6960
Error code 1275 - This driver has been blocked from loading
Chances is that your computer has registry problems.
Use a registry cleaner software to scan & repair the problems.
Hi,my 2012 navara will not produce power,mil always on even after reset,fault code is 1275,what could be the possible problem and solution?thanks
code p 1275 refers to heated oxygen sensor(HO2S) 1 --response time ===causes --HO2S sensor---injectors--intake air leak---exhaust leak-----MAF sensor
take it to a service centre for an exact diagnosis as it could be either the HO2S or the MAF sensor or a combination of both
a service center with experience on your make of vehicle will be able to test each and see which is faulty
1helpful
I have change pressure sensor DENSO 6100 on Nissan X-trial 2005 It was p0089 error code now I have two p0089 and p1275
code p 0089 refers to fuel pressure regulator---performance problem===causes fuel pressure regulator---mechanical fault
code p 1275 refers to heated oxygen sensor (HO2S) 1--response time===causes--- HO2S--fuel pressure--injectors--intake air leak--exhaust leak--MAF sensor
as the pressure regulator ( fuel pressure) appears in both codes I would be paying attention to that unit first
Error 22
Error 22 does not seem to be an error code according to the manual:
http://h10032.www1.hp.com/ctg/Manual/c02007321.pdf
Fixin to buy one.How old are these laptops? COMPAQ presario 1275
It is very old laptop 1275 had windows 98.it is one of the oldest laptops
no one will buy it
I have an error according with my printer EPSON ACULASER C8600 { CODE E510 }
This error code refers that your motor is not functioning properly. You better go for servicing or support from the service center. For more error codes and causes, you can check out this link below http://www.theprinternetwork.com/printthread.cfm?Forum=116&Topic=1275
1helpful
Error e510 encountered in epson c1100
This error code refers that your motor is not functioning properly. You better go for servicing or support from the service center. For more error codes and causes, you can check out this link belowhttp://www.theprinternetwork.com/printthread.cfm?Forum=116&Topic=1275
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
2helpful
System disc error Compaq Pesario 1275
This is either an issue with the CMOS batter which may need to be changed, I have seen this error on thinkpads and one way of resolving it is to install an older BIOS, you can download a BIOS from your machine and install it using there instructions
Hope this helps
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
BIOS Clock Error
Update the BIOS or CMOS it should be fine after that.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
