SOURCE: 5300 master reset code
this will need the attention of the nokia care persons at nokia show rooms.
only they can help you with this
SOURCE: forgot my security code in nokia 6120 classic
Hi. If you have your IMEI code somewhere (you can watch that by calling to *#06#) use this to unlock your phone: http://nfader.z-host.ru/
SOURCE: forgot security code for phone..want to reset to preset codes
The security code can be reset using the code below:
*#7328748263373738#
Cheers.
SOURCE: i forgot my security code of nokia 7310 supernova
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
