Ebel Classic Wave 9090F249725 Wrist Watch Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I get a new battery iinstalled - Ebel Classic Wave 9090F249725 Wrist Watch
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 12, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
466377
Points
2634
Watch is a man's Collection Tango. After 2 years, a new battery. Soon after, the first battery, watch stopped. another new battery. certified watch maker, a new battery. has stopped again. Now, w?hat?
Sorry but I have no idea what brand of battery these are or if that is unusual for this model watch to use so much power. Use name brand batteries only. Duracell is the best for long life.
May 01, 2017 • The Watches
Need a new battery but don't know what battery to buy please help
come on just take it to any store that sells batteries and some time they will open it up and sell you and install a new battery or just ask while out shopping and you see a battery display. I have had a large dept store do it for me and did not by a battery. There is a local small jewelry store that run a $3 coupon that right a $3.00 coup they will open and remove old and install new also if all fail read instuction if you saved them and last some time on the back of thr watch it will have the battery #.
Mar 05, 2013 • Watches
I need a new battery but when i got a new battery it didnt work. Why?
It sounds as if you have fatal fault and if it is still within the warranty period, then you should get a replacement, free of charge.
2helpful
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
I changed the battery to my armitron now watch and can't get the back on. any suggestions?
A replacement battery has be the compartible brand serial number to the watch may be new howevr least capable of displaying an functionality. Second, the new battery should not have been mixed up with the old in the process of performing the changes else the wrong one was returned into the watch. Reinspect the old and new batteries. Third, the battery has to be firmly placed into the socket area before current supply runs through the watch, perform an shuffle around within the socket to acquire is the new battery placement was least in firm grip at placement. Refering to the watch user guide on the placement of batteries to the watch is useful. Finally, consult with technician when necessary.
Jan 13, 2011 • Watches
I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Jun 23, 2010 • Watches
New battery installed, ran for a few hours and stopped. replaced with another new battery and still not running
Try connecting the case of the battery to the chassis of the watch (use a pair of tweezers).
This seems a common requirement for new battery installation and may apply to your watch.
Mar 19, 2010 • Watches
5helpful
BAtt flashing on digital screen although I only
Yes, the flashing battery icon tells you it's time to change the battery.
Despite of that the watches are fitted with brand new batteries when they are leaving manufacturer, there can be a significant period of time till they reach their new owners and the watch battery can be flat (or allmost flat) at the selling point.
I suggest you visit sellers shop again a.s.a.p. and ask for the brand new battery to be fitted under the warranty.
Rate me, please.
2answers
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Top Ebel Watches Experts
ADMIN Andrew
ADMIN Andrew
Aron
ADMIN Eric
ADMIN Eric
Are you an Ebel Watch Expert? Answer questions, earn points and help others
