The issue is from settings , in fact from modes..the camera is set in a low light mode..and in normal conditions makes pictures very bright ..so ..if it has separate button for modes..just put it back to normal ...or if it is a fully digital menu ..look for modes..and adjust in normal ..or after case in sunny or other setting is available ...or ..just look in the main menu and rest all settings to the factory defaults ..
Hi. Thank you. I spent the recent days to fix the problem by trying changing the settings. Maybe I don't know exactly what to do. There are settings for the vidieo, for the camera and general setup.
Can you tell my specificly which setting to change?
Hi. Thank you. I spent the recent days to fix the problem by trying changing the settings. Maybe I don't know exactly what to do. There are settings for the vidieo, for the camera and general setup. Can you tell my specificly which setting to change?
try in th egeneral settings to look for reset .settings ..cause this will reset it to the factory settings ..than ..if this will not fix it ..or if you do not have a general reset ..in the camera menu ..look for modes...there has to be something either called modes..(sunny ..cloud ..indoor outdoor..etc ..and normal) or by icons....put in the icon that shown both cloud and sun ..
