Casio G-Shock G 520D 4AVDR  Cockpit Series watch Logo
Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant set it - Casio G-Shock G 520D 4AVDR Cockpit Series watch
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 19, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
466377
Points
2634
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
1helpful
I cant set time on watch
is this your watch?
more than likely the stem may be a little stiff to pull out. grab the crown firmly and pull with your fingernail. i don't recommend using a tool. most jewelers have a person who can address this if you can't get it. and they if really only spent a moment to set your watch, they typically won't charge you. if they have to pop the case, it should only be a few bucks. but try a little harder to pull it out yourself...
May 09, 2013 • Watches
I cant set up my watch
Press and hold the set button. After about 4 seconds the display will start flashing. You can just walk through each setting as they come up.
murf427
Oct 25, 2012 • Watches
20helpful
2answers
Roberto vecci radio controlled watch instructions i cant set the analoge time
i HAVE RDIO CONTROLLED WATCH NUBER 02390 PUT A NEW BATTIER INIT BUT i CANT GET IT WORK RIGHT,DAVID
2helpful
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
10helpful
I have lost the instructions and cant set the time
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
Mar 27, 2010 • Watches
I cant figure out how to set the time and date on an armitron mens M516 all sport 40/6753
I cant figure out how to set the time and date on the armitron instalite
4helpful
Sport tag h cant set time
The crown is lock that's why you cant pull the crown to set.The crown has a thread that lock, you must winding it clockwise to unthread it, so you can set the time..
Regards:
VOTIT
Dont forget to rate:
1helpful
2answers
Cant set time on watch
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers
May 04, 2009 • Watches
Top Casio Watches Experts
Robert
Narseman
Are you a Casio Watch Expert? Answer questions, earn points and help others
