SOURCE: computer reboots after about 2-5 mins, OR hangs on high 3D graphics games
The card works fine whit no driver, but hangs or reboot after a few min. with latest drivers from ATI (maybe they return to theyr habit of making bad drivers :( again). PS: heat problem is out of the question (3 minutes in 12C enviroment temp with open case). DXdiag crashes on Direct3D test. Some game and all aplications works fine for hours, so I don't think is a heat problem
SOURCE: Graphics Card is not supporting Direct Draw
ensure your mainboard is capable of 8X AGP speed. also try to re-install video drivers.
SOURCE: Blue screen of death when playing 3d games
How do you connect to the net? wireless? Also, newer drivers dont always mean better. This problem is most likely driver related. Try rolling video drivers back to the earlier version. If connection is wireless, try reinstalling modem drivers also.
SOURCE: i can't play zoo tycoon 2 with VIAKM400 graphics card
GO INTO CONTROL PANEL AND GO TO PERSONIZATIONS AND OPEN DISPLAY SETTINGS, OPEN ADVANCED SETTINGS,
OPEN THE FOLDER THAT SUPPORTS YOU VIDEO DRIVERS DEVICE IT MAYBE CALLED CONTROL CENTER
MINE SAYS CATALYST CONTROL CENTER OPEN IT
OPEN ATI CATALST CONTROL CENTER
YOU WILL FIND THE FOLLOWING INFORMATION ABOUT YOU SYSTEMS ADVANCED SETTING SO YOU CAN PLAY THOSE GAMES.
INFORMATION CENTER
HARDWARE SETTINGS
SOFTWARE SETTINGS
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES
3D THIS IS THE ONE YOU WANT TO HELP YOU PLAY YOUR GAMES GO TO :
ALL SETTINGS
MORE SETTINGS
COLOR
AVIVO TM VIDEO
POWER PLAY
ALSO SOME WHERE IN THESE SETTING IS WHERE YOU MAY CHECK A BOX FOR THE GAME THAT LOAD CERTAIN DRIVERS FOR EACH GAME BECAUSE ALL MFG DONT HAVE THE SAME SETTING FOR THERE GAMES SO CHECK THE BOX
THEY START GAMES WITH NUMBER 1ST
THAN FROM A-Z
BEST OF LUCK.
ROD
SOURCE: i have a nvidia Gforce 128 mb graphic card and it doesnot work
What is the exact model Nvidia GeForce card that you have and what brand is it?
Have you tried the card in another PC to test it? That would be the ideal way to confirm it's a card issue.
Let us know...
