Error Code 51030, 51031, 51032
It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Hi
there
you
have the error code 51030, you can fix all error codes easily
This
needs to be repaired.
you
can send the console to Nintendo for free if in warranty, if out of
warranty then this will cost you around $150, the whole process will
take 4-6 weeks
I
prefer the Wii repair
guide Method, download the guide and follow the simple step by
step instructions and fix the problem in less than an hour, no
hassle, low cost everybody is happy.
Best
Regards
WiiRestore
Feel free to leave a comment if you need assistance
