Display shows "Timer 1 End" with the "1" flashing.
Cancel button does not get rid of the message.
Timer 1 on/off, Timer 2 on/off, and Setup button all not responding.
SOURCE: My whirlpool duet washer has stopped mid cycle and
Sounds like the timmer in the control module has frozen and will not advance. It's one module for the whole display. I sometimes tap the module with a plastic screwdriver witch may releace it but it will do it again. I sorry to say but it's time for a repair man. I do't have the writing space to tell the procedure (if it is the problem) - Sorry, not good news
SOURCE: key do not work #'s 1 & 2, Lower bake , broil,
Hi
You'll need to check the oven temperature sensor and the contacts on the power relay board (PRB). You'll need a multimeter to check the resistance of the temperature sensor, multimeter would read between 1140-1150 ohms. If you notice any deviation in the reading then you'll need to replace the temperature sensor. Hope this helps... Please post back with model # if you need more information.
Daniel
