Hi, i can help you with a master code but you need to know something first.
1. if the wrong code has been entered more than 5 times then the phone is hard locked and can only be unlocked using flash lead and unlocking software.
so if you have not entered more than 5 wrong guesses then i can get a master code that resets the security code to what it was when new and it removes the security code untill you choose to use it again.
What you need to give me is your imei number this is found on back of phone under battery and looks like 123456/12/123456/1.
its 15 numbers long.
I need this code because every single phone has a set master code based on the imei number. i have the software to generate these codes as i worked for nokia for years so i can help you but let me know then i can assist you further ok.
My is nokia Corporation
Model rm-987
Type rm-987
FCC ID QTLRM-987
CODE 059V7T7
IMEI 351739/06/021338/4
How can i unlock the security code for nokia 6230i
hi there i have a similar problem, my imei is 356223/00/600521/7. My phone will accept any other sim card, only it has a call barring in or out going calls. I forgot the 4 digit pin number. Help will be appreciated.....
really i want your help this is my phone imei 359740/00/118708/5 waiting ur solution on ra2fat1210@hotmail.com or at any place !!
can anyone to brake my phone code by imei, my handhone is N73
detail :
V4.0736.3.2.1
04-09-2007
RM-133
c Nokia N73 (12)
my imei: 358973011580244
