RCA 191409 Microwave Oven Logo
Posted on Sep 25, 2010
What does error code 230 mean? - RCA 191409 Microwave Oven
1helpful
Model # JMV8208BAS
On a GE or Hotpoint, it usually means the keypad is defective. On some other brands, it means there's a sensor error.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
How to fix a se error code on a kenwood microwave
Do you mean KENMORE microwave? SE error code typically means a bad control panel keypad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Kenmore elite microwave troubleshooting
<- If you had listed your error code, I would probably have been able to tell you what it means.
But of course, I'd also want the full model number from the tag on the unit.
You can also look here:
http://www.appliancepartspros.com/repair-help/appliance-fault-codes.html
Error E:02 comes up
Hi nic_marlon,
The meaning of the error code depends on what brand of your machine is. If you can provide it to me I can give you accurate information. On Westpoint this error means you have a temperature sensor error. The sensor is damaged or faulty.
Hope it helps.
Thank you for using Fixya.
9helpful
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
1helpful
Microwave keeps beeping and the Code 230 comes up. Do I have replace the darn thing??
Hello there and thank you for choosing Fixya
The problem with the 230 error code is that it covers 3 0r 4 possiable items but here is what it could be
If the number showing in the display is higher than 213 you more than likely have on of the following problems; sensor failed open, sensor unplugged, wiring, or smart board.
Most of the time i have found it to be the sensor
looks like any one of the 2 i have listed belowtbirdfan1_52.jpgtbirdfan1_51.jpgtbirdfan1_50.jpg or it could just be your circuit board ok So check these out first Hope this helps mike
Top RCA Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Anonymous
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
