Konica Minolta bizhub C351 All-In-One Laser Printer Logo
Posted on Sep 26, 2010
I have the error code C-2251 on my bizhub C351
5 Related Answers
Jonathan Hilbun
  • 30 Answers
  • Posted on Jul 18, 2008
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
carpediemweb
  • 54 Answers
  • Posted on Jan 10, 2009
SOURCE: Error 2652
C2652 Magenta Imaging Unit EEPROM access erro. you need to:
1. check if EErpom of Magenta Unit is not dirty. if it is, clean it.
Else, replace the Unit image.
Anonymous
  • 51 Answers
  • Posted on Aug 30, 2009
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
Anonymous
  • Posted on Jan 11, 2010
SOURCE: print error page Bizhub C351
hello
I resolve the same problem by restart (power off power on) the switch with pluged Bizhub C360.
Maybe it will help someone.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
