Carrier BCA101R Air Conditioner Logo
Posted on Sep 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't cancel the timer - Carrier BCA101R Air Conditioner
Level 3:
  • Carrier Master 17,130 Answers
  • Posted on Sep 27, 2010
Carrier Master
Level 3:
Answers
17130
Questions
0
Helped
3710726
Points
52372
Remove the plug offf , remove battery from the remote for some time. the timer must reset now.
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
I have the timer light alone one and cant get the cd player to go on please help me
UNset the Timer control. On Page 40 of the manual...
Cancelling the timer setting in the timer stand-by mode:
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE" or "DAILY", and press the MEMORY button.
3 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY button.
Timer will be cancelled (the setting will not be cancelled).
1helpful
2answers
The power light is not coming on,only some timer light
IM NOT GETTING ANYTHINK WHEN I DO THAT NOTHING AT ALL ITS JUST THE RED LIGHT FLASHING :(
My rinnai rce 229 will only start on timer button it will switch off on on/off button but then will not switch back on with on/off button it will only switch back on with the timer button help.
To cancel the ON TIMER here's what you need to do:
Press the "ON Timer" button or press the "ON-OFF" button.
The setting will be canceled and the timer indicators will go out.
TO RESET THE UNIT
The ON Timer will be canceled if the power plug is removed from the power point, a power failure while
the appliance was in standby mode, or if the ON Timer setting is canceled. "00" will flash on the digital
monitor when power is reinstated. Pressing the ON button and starting the unit will delete the =00".
Hope this helps you.
How do I set the timer?
Press the self-timer button. It's the bottom part of the cross-shaped button on the back, marked with a clock icon. Each press of the button cycles between ON and OFF.
After pressing the shutter release button completely, the self-timer lamp lights for approximately ten seconds, blinks for approximately two seconds, then the picture is taken.
To cancel the self-timer, press the button again.
The self-timer is automatically canceled after one shot.
1helpful
2answers
Unit will not come on, but timer button is blinking
Well, it thinks it's set to come on under Timer control.
Get the manual out (or go to retrevo.com, register and download it for free) and go to page 34 and cancel the timer.
Canceling the timer setting in the timer stand-by mode:
2 Within 10 seconds, press the or button to select
"ONCE" or "DAILY", and press the MEMORY/SET button.
3 Within 10 seconds, press the or button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY/SET button.
Timer will be canceled (the setting will not be canceled).
I need to know how to cancel a wake up
make sure the power is off
press ex bass to check which programs are set.
to cancel
press srs 3d till all timer lights are off
it cycles prog 1
prog 2
prog 1,2
timers off
Cheers!
Cancelling a Timer Recording
Hi , to cancel just push the record push button .
Top Carrier Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
jdthefixer
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
