KDS Valiant 6380iPTD-01 Notebook Logo
Posted on Sep 28, 2010
Error code e75 - KDS Valiant 6380iPTD-01 Notebook
1helpful
Error code E75 in al frigidair affinity FAFW3801Lw3. What I need to do? help please. Thanks!!!!
E75 has nothing to do with the spin cycle, pump, door switch, or anything like that. E75 means there is an issue with your temperature sensor circuit. That is part of your control board, which means that the control board will need to be ordered and replaced to fix the E75 error code.
E75 default code on Electrolux gallery series dryer
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
1helpful
E 75 code stop machine from spinning
E75 has nothing to do with the spin cycle, pump, door switch, or anything like that. E75 means there is an issue with your temperature sensor circuit. That is part of your control board, which means that the control board will need to be ordered and replaced to fix the E75 error code. Here is a link to the part you need to order.
My nokia e75 gives me a system error on its screen
My Nokia E75 gives me system error how can I fix ths
7helpful
2answers
9helpful
3answers
Forgot lock code nokia e75
Sir i am using Nokia E75. My IEMI Number is :359557017656626. I forget my lock code . plz help me to unlock my phone. my email id adnanjee2010@yahoo.com
E75 error
Looks like micro controller board problem!
5helpful
4answers
Unlocking nokia e75
For unlocking Nokia E75 follow the instructions given below & get the unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/ & unlock your mobile in easier way ..
Warning : Do not enter any wrong unlock codes on your Nokia E75 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E75 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E75 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E75.
3 - Compose #pw+CODE+1#.
4 - The Nokia E75 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E75 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E75
Jul 27, 2009 • Cell Phones
E75 What is it
have u try to update or flashing the firmware the dvd drive of your 360or check the sata cable or the power cable of the dvd, try it .... because the code 1023 is dvd drive problem and if that tricks fail maybe the drive was broken.
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Kirk Augustin
Kirk Augustin
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
