Hello,go to back side of printer & open the flap u will found two serews open them push the tray & open the two locks at right & left bottom then back pannel will come out.pullout the white strip where the power connector inserted you will find fuser connector (black,white wires)open 4 screws on which fuser wire attached detach two connectors situated right side wall of printer& you will find a teeth lock on the bottom side of fuser press the two leavers & pull outwardly & also pull out the unit outwardly & do as viseversa for fixing the unit.
