SOURCE: Canon iR C3220 Control Panel
Hi Ing,
I am not "at" a 3220 but I will try to visualize. On the "op" panel to the right of the display is a button that looks like an asterisk and says additional funcions.Press it. Bottom left tab says "system settings". Press it. New menu,right side , second tab, says network settings. Press it. At that point you should see tcp/ip settings. Press this tab and you will see the ability to manipulate many of your network settings."NOTE" this device is indeed capable of supporting being set to DHCP. You of course understand the pitfalls of having a printer set to dhcp. It is almost always recommended that a printer/scanner/fax/document server/ have a static ip address. However the right IT person in the right network enviromentwill have no trouble at all with this device. hope this helps, and if I did help please let "FIXYA" know it .Good luck and take care. .....................SPINAL........
SOURCE: Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
SOURCE: canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
