SOURCE: code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
SOURCE: What is the remote control code?
I finally got mine fixed yesterday. The room code has to be set to 1. The VIP 612 has to be on. A phone call to Bose provided me with about 4 more codes that were not included in the setup manual, and one of them worked. Good luck with the set up, hope this helped.
SOURCE: code for uverse cisco box to bose cinemate series
hi i do have here a couple of codes for bose
4000, 2130, 2215, 2276, 6060,
5007
hope this helps! goodluck!
SOURCE: Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
