Posted on Oct 20, 2010
How do you delete memory from a 2030 Pitney Bowes fax machine?
5 Related Answers
Anonymous
  • 2120 Answers
  • Posted on Jan 31, 2009
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Anonymous
  • 18 Answers
  • Posted on Aug 24, 2009
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Nike Merritt
  • 149 Answers
  • Posted on Oct 10, 2009
SOURCE: Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Nike Merritt
  • 149 Answers
  • Posted on Dec 21, 2009
SOURCE: Pitney Bowes 1530 Memory Full
1. Press FEATURE
2. Press 9 9
3. Press * * * 1 (this is the service passcode)
4. PressYES
press 095
press yes
press stop to exit
Nike Merritt
  • 149 Answers
  • Posted on Dec 24, 2009
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
2helpful
1. Press FEATURE
2. Press 9 9
4. PressYES
press 095
press yes
press stop to exit
1helpful
1helpful
Pitney bowes 9820 error message
7helpful
2helpful
9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
