Kenmore Oasis HE 27062 Top Load Washer Logo
Posted on Jun 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code I get an error code dL. What does this mean?
  • Anonymous Aug 04, 2008
    washer stops and flashes dl error can't wash.
Anonymous
Level 3:
  • Master 525 Answers
  • Posted on Jun 06, 2008
Anonymous
Master
Level 3:
Answers
525
Questions
Helped
274430
Points
1510
If you see "dl" or "du" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can click on the following link if you need step-by-step instructions on how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hope this helps!
Thank you for contacting us at FIXYA.com
1 Related Answer
Anonymous
  • 126 Answers
  • Posted on Jan 28, 2009
SOURCE: Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
What does F --DL code mean
with out a make or model number I think this code means problem with the door lock
https://www.hunker.com/13410537/how-to-fix-a-dl-or-f-error-on-a-whirlpool-duet-washer
https://www.youtube.com/watch?v=_BsaIsSlxNY
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
4helpful
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
1helpful
What does code dl mean
The "dL" error code means that the door/lid can't lock. Check to make sure nothing is stopping the lid from closing and locking. If everything looks ok, then you either have a bad door lock or a bad control board.
For about a week now, my Kenmore Elite top loading washing machine has the error code dL at the end of the cycle. There is a lot of clicking noises and then it displays the code.
Means a failed lid lock mechanism. You should replace the lid switch in the unit which will alleviate the dl error code. If you have any further questions message me back I await your reply Thanks Rick
2helpful
What does f dl mean
Hello, F DL means
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Ohm out the door lock solenoid and the door lock switches. This is most conveniently done at the central control board--use the wiring diagram/tech sheet to locate the proper pins to test from. Unplug the washer before starting work.
Thanks
2helpful
Door is locked dL error code
DL error code means the door is locked. The door lock mechanism may need to be replaced. I would not recommend attempting this on your own I suggest you call a service tech.
Error code DL...
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
