SOURCE: We have an error code on the water dispenser
You have a ice fan motor problem. This fan motor is what feeds cold air to the icemaker. Try unplugging the refrigerator for a few minutes to reset the computer. Plug it back in and see if the error code stays off. If it returns, you will need to remove the ice fan motor from the freezer and see if ice has built up and blocked the air flow. The ice fan motor is located behind the back wall inside the freezer. You will have to remove the drawers and slide supports to remove the back wall. There are 2 fans behind the wall. The one on the left is the ice fan motor. Good luck.
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The
fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it
thaw. Also check to see if something may have gotten into the vent
holes in the freezer that could be blocking the fan from turning.
SOURCE: kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
SOURCE: LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
