SOURCE: I have just replaced the
To all who need to change their Timex Ironman Triathlon watches:
It is a little confusing, but this is a watch you can change the battery by yourself!
First you will need:
-A big clear area (i.e. a table or counter) with lots of light to see what exactly you are doing.
-Small screw driver (like the tiny ones for a glasses care kit)
-Paper clip
Directions:
1. Remove all screws from the the back of the watch (there should be 4). Make sure that you take note of which screws are coming from which spot on your watch and keep them separated as such.
2. Next, you should see a white circular sticker with directions on how to change your battery. They aren't clear as "how to" but they are the basics.
2a. Take off the white sticker once you have memorized the places it is pointing to; set it up as such in front of you so you can refer back to it from time to time.
2b. You should see two silver pieces. One should be a circle (which is the battery), which is held in by another silver piece. This unlatches. In order to do so, you need to simply pop it open on one of the sides (as it tells you in the directions). You may use the same screwdriver or even a paper clip works wonders!
3. Replace your battery (should be CR2016) with the + on top, facing towards you. make sure it is flat, not just shoved back where the old battery was. This make take some extra time and patience to make sure it is done right.
4. Snap the silver part back into place (should look like it is holding the battery in place i.e. a gate).
5. THEN: this is the most important and confusing part in my opinion. On the white sticker the directions read: "after battery insertion, short pads to reset". this should look something like an oval with a line cutting it in half (vertically). It is not on the battery but next to it. You will need the paper clip here to hold down the right most side (at somewhat of an angle). this should do it! you'll know if your digital faces flashes numbers at you and may even light up. Make sure you hold down long enough.
6. Once you have the numbers flashing, you are good to go. Put the back of your watch back on, taking note of which screw goes where. Then, set your watch accordingly and you have just changed your watch! Ta-da!
Follow these steps and you should be good. Good luck to all!
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
SOURCE: I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
SOURCE: how do i set date and day of week on timex indiglo
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
SOURCE: I have a Timex Ironman
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
