Cisco Interface Module 1-port Channelized E1/ISDN-PRI Modem Logo
Posted on Nov 01, 2010
Hi I have a problem with calling out from my Cisco 3845 router ISDN Channelized E1 port to a Huawei Softx3000 switch. This is the debug I am getting Direct inward dialling on this port works fine. Oct 29 08:45:19.209: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8014 Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info Progress Ind i = 0x8288 - In-band info or appropriate now available Progress Ind i = 0x8288 - In-band info or appropriate now available Oct 29 08:45:34.217: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8014 Cause i = 0x829500000000DC - Call rejected Oct 29 08:45:34.261: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8D7F Cause i = 0x8295 - Call rejected Oct 29 08:45:34.349: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0014 Oct 29 08:45:34.401: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0D7F Oct 29 08:45:34.425: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8D7F Oct 29 08:45:34.449: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8014 Any ideas?
2 Related Answers
J John
  • 299 Answers
  • Posted on Sep 02, 2010
SOURCE: How to create subinterfaces on a 3845 series cisco router
Its like router on stick configuration??enter the interface which you have to configure and in that interface as mentioned below
Hostname(config)#interface FastEthernet0/1
Hostname(config-if)#no ip address
Hostname(config-if)#no shutdown
Hostname(config)#interface FastEthernet0/1.1
Hostname(config-if)#encapsulation dot1Q 1 native
Hostname(config-if)#ip address x.x.y.y < subnet mask >
interface FastEthernet0/1.2
Hostname(config-if)#encapsulation dot1Q 2
EngineerMC
Martin Clarke
  • 186 Answers
  • Posted on Jun 16, 2012
SOURCE: How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Kirk Augustin
Kirk Augustin
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
