Exercise & Fitness Logo
Posted on Nov 14, 2010
E5 sensor error code true treadmill - Exercise & Fitness
4 Related Answers
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Nov 24, 2011
SOURCE: e5 error code on sportcraft tx400 treadmill
E5 error code means that your treadmill sensor goes out and require calibration. Just try with TechnoGym and following the procedure to calibrate the sensor.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 25, 2011
SOURCE: e5 sportcraft tx400 treadmill
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedsincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
See the schematic how the Main Controller has 90% functions in Treadmills
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Mar 15, 2012
SOURCE: how to solve the E5 sensor error code true treadmill
Dear Sir:
This error come because the power up test the sequence. The test is performed beacuse a permanently STUCK key inhibit the correct operation.
Liquida or perhaps perspiration in present on the surface of touch sensitive display. Try to remove the keypad connector cable. Restart the power is the ERROR 5 is not longer presente the keypad is the cause. If do the display housing is the problem
Run the software calibration for eay diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 12, 2012
SOURCE: E5 senson message appears after I starp up my True 450 treadmill
see this causes and remedy, and fix it. God bless you
However RUN the software calibration for diagnostic, troubleshooting.
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Top Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
