Whirlpool RBD305PD Electric Double Oven Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the problem with the oven when it shows codes E6 F2
Kelly
Level 3:
  • Whirlpool Master 3,740 Answers
  • Posted on Nov 21, 2010
Kelly
Whirlpool Master
Level 3:
Answers
3740
Questions
Helped
2226279
Points
12091
Hi and welcome to FixYa, I am Kelly
The error & fault code "E6 F2" is a keypad or keypad connector problem. However... the control board can also cause this fault. Sometimes you can clean the ribbon and connector at the control board attachment point and correct this.
There is a tech sheet inside the control panel (envelope) that has all of the error codes listed.
The control boad has a female connector with 2 release tabs for the ribbon. YOU MUST unlock the release tabs to remove the ribbon. This is a tedious process but if your gentle and take your time you can coax the ribbon out of the connector. The contact area of the ribbon is quite thin. I have found that you can place something non metalic and FLAT behind the ribbon and then use a tissue to gently clean the ribbon wiping in the same direction of the electrical runs on the ribbon. I.e. wipe from above the bitter end down to the bitter end. (one direction only) The female connector on the control board is much more forgiving. Once you complete the cleaning process press the ribbon back into the female connector and lock the 2 tabs.
If this does not correct the problem you can end up changing the control board (1st) and the touch pad (2nd) to fix it.
If you need help with locating parts just respond here and I will gladly assist you.
Thanks for choosing FixYa,
Kelly
  • holthaus Sep 19, 2011
    Can the ribbon alone be replaced without the control board? One of the contact areas on the ribbon appears to be scraped off by careless assemblers. Thanks!
  • Kelly
    Kelly Sep 19, 2011
    The ribbin can be replace but good luck finding one. You might be able to peel back the outer plastic of the shorter side of the rippon and trim the end if it is at the main board connector. You would have to punch new connector lock tab holes also. Good luck.... A tedious task but possible.
Top Whirlpool Ovens Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
