Ricoh CL4000DN Laser Printer Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code error 307 ricoh CL4000DN - Ricoh CL4000DN Laser Printer
gggg
Level 3:
  • Master 904 Answers
  • Posted on Feb 09, 2011
gggg
Master
Level 3:
Answers
904
Questions
Helped
529193
Points
1791
Sc 307 is a charge bias error having to do with the yellow photoconductor unit (PCU). Replacing the yellow PCU should resolve your problem. If the problem persists even with a new PCU, you will likely need to have either the high voltage supply board or the drum positioning plate replaced.
Thanks for using FixYa!
Ricoh Alficio has a few errors sc202 Sc792. Any ideas how to fix appreciated Thnx
In order to clear error SC542, you must perform procedure 5810.
  1. Press and hold online + escape, then power on.
  2. Use up and down arrow keys to select SP2.
  3. Press Enter.
  4. Use up and down arror to locate SP5.
  5. Press Enter.
  6. Use up and down arrow keys to select 810.
https://finsterbt.com/ricoh-cl4000dn-error-code-sc542/
1helpful
SC 491 error message
sc 491 is error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective high voltage supply unit
SC542 Error
First fix fuser unit thermistor bad then service mode and rest set code
3helpful
2answers
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
1helpful
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
3helpful
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
1helpful
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
1helpful
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
4helpful
2answers
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
2answers
Thermistor Location on Ricoh CL4000DN
Thermisters are located in the fuser unit. They contact the rollers. Good luck
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
