The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
Defective DC Controller PCB Assembly.
Action
Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
Remove and reinstall the Laser Scanner Assembly.
Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
