You can download the youtube videos to your PC and then convert them for the PSP format... If that's what you want of course.
Jules
No there is no way to watch youtube but you can get on psponme.com and play some free online flash games
Because the PSP's web browser only supports an older version of flash, YouTube uses flash 9. If you want to watch YouTube on PSP directly with the wifi, you must upgrade the newest firmware for your PSP and install a flash player on your PSP. A Japanese developer NekoMiMi has achieved just that with PSPTube. Here are the steps
Step2Download the PSPTube and open the zip file from here(go to Resource, the below link)
http://www.PSP-hacks.com/file/1225
Step3Now before putting it in your PSP open the PSPTube.cfg file and press ctrl + F, and type in "DEV" press until you find Dev id="".
Step4Ok now go to http://www.youtube.com/dev(go to Resource, the below link)create an account and insert the account in between the parentheses.
Step5Extract the PSPTube from the 200over folder and put it in GAME352 folder (Set the Kernel to the 352) Now open it in the PSP and Choose an internet connection with the Circle button, it may say no videos, press circle and you'll be able to search.
Here is the control info:
X: Cancel; O: Accept; L/R: Last/Next Page; Start: Pause;
Select: Change aspect ratio (Original Size, Full screen)
Step6Download free YouTube video to PSP
If you have Firefox browser, you can follow these steps.
(If you want to capture stream video from internet, the way is the same)
Step7Install the videodownloader extension. This is a plug-in for Firefox. It enables you capture streaming video from website. Here is the Download link: https://addons.mozilla.org/firefox/2390(go to Resource, the below link)
Step8
After installing videodownloader, restart Firefox. In the bottom right, you'll see a little box. Go to the video you want to download, double click that little box, and select download link. Then you could download the streaming video you want. (Note, you have to rename the file extension from "html" to "flv")
Step9
You have to rename the file extension from "html" to "flv" when you save the link. (Make sure your compute is show file extension)
Step10
The downloaded YouTube video is flv format, so you must convert video to mp4 for psp, download Aimersoft PSP Video Converter; you can free download it from here:http://www.aimersoft.com/psp-video-converter.html(go to Resource, the below link)
Step11Install and run Aimersoft PSP Video Converter, click the "Add" button to import your videos. Aimersoft PSP Video Converter supports batch conversion, so you can import multiple files at a time. If you experience any problems adding videos by directly clicking the "Add" button, you can click "File -> Add DirectShow files..." to add the video files you want to convert from your computer.
Step12Then Click the "Format" drop-down list to select the format you prefer for each added file. If you don't know what formats your device supports, you can just select the format according to the device name.
After all things done, click "Start" to start conversion.
Step13After conversion finished, connect psp to pc using a usb cable go to psp select usb code. then open the memory stick on pc, you will see lots of files, make a new folder called "VIDEO" on "MP_ROOT" then copy your MP4 file to this folder, or you can use psp video manager that is builded in above PSP Video Converter, it can help yo transfer video music to psp directly.
Hope that helps........
