Hi John and welcome to FixYa, I am Kelly. I am assuming this is a mini model with a flatened circular type tank under the oil-less Pump and motor. Since I do not have a model number yet.... a few things come to mind that can cause your situation. (in no particular order)
1. The pressure switch contacts failed.
2. The start capacitor has failed.
3. The run capacitor has failed.
4. One of the 2 windings in the motor have failed.
Which one of thses units is yours?
http://www.mastertoolrepair.com/devilbiss-free-electric-c-271_36_241_398.html
Kelly
Hi again, I do not think it was because it is too cold. It is possible but the fact you ahd used it and it was already warm sort of rules that out. You are going to have to read the motor winding at the pressure switch by reading for continuity / resistance across the 2 output terminals that go to the motor. If there is no resistance then the motor winding has failed. If there is resistance.... for testing only connect the power lead directly to the motor terminals of the presure switch. Do not let the unit run for very long. (If it runs at all!) If it does run.. then the pressure switch has a problem and it should be replaced.
Here is the Parts list:
http://ipl.ordertree.com/ipl/Black%20and...
Item 34 appears to be the pressure switch. It is not shown in the details.
PN: Z-DAC-4105-2
These switches are very common and can be purchased at home improvement stores and Sears.
I do not see any start or run capacitors for this unit... only power, pressure switch and the motor.
Kelly
The manuals for this are about a clear a mud. If you have capacitor(s) on your unit.. to test them you set the meter on R X 10,000 and probe the capacitor terminals. You should see a brief jump and then the meter return to infinity. Reverse the test leads and do it again looking for another jump... EACH time the leads are reversed. No Jump = bad capacitor. If it reads constant resistance it is shorted internally. That is about the best I can do from here John. Feel free to ask any questions. I am not sure if you noticed but... you clicked on problem solved so you will see a debit for your post. I will still answer anything you post. Let me know what you found out.
Kelly
Thanks Kelly. The model no. is PAFA125-1. It is an elongated, horizontal tank. I am working outside with it, blowing out the water lines on my camper. Is it possible its too cold? It might be around 32 degrees.
Thanks Kelly---I'm not much for electicity in small motors, so I'll take your comments to a friend who will take me through it.
