Hello Programming channels automatically Your TV can automatically detect all active channels and store them in its memory. After the TV has stored the channels in its memory automatically, you can add or erase channels manually. To add channels automatically: 1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu. 2. Press "Up arrow"or "down arrow" until the TV/CABLE selection is highlighted. 3. Press "left arrow" or "right arrow" button to highlight either TV or CABLE, depending on which you use. If you use an antenna, choose TV. If you use cable, choose CABLE. 4. Press "down arrow" button until the CH PROGRAM selection is highlighted. 5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically cycle through all the TV or Cable channels (depending on which you selected), and store all active channels in the channel memory. While the TV is cycling through the channels, the message "PROGRAMMING NOW-PLEASE WAIT" appears. 6. When channel programming is complete, the message "COMPLETED" appears.
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
