Minolta DiALTA Di183 Copier Logo
A
Anonymous Posted on Dec 16, 2010
Error code C0601 Error code C0072 - Minolta DiALTA Di183 Copier
Norman Weimar
Level 3:
  • Minolta Master 7,080 Answers
  • Posted on Mar 01, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7080
Questions
Helped
1997807
Points
12012
For the 0072 try this:
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
As for the 0600 code the scanner the bright lite under the big glass is not lighting replace the lamp and board
as for the
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3 Related Answers
Anonymous
  • 15 Answers
  • Posted on Apr 11, 2009
SOURCE: error codes for EP 2050 is C0072
See the hopper unit or toner botle
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Apr 16, 2009
SOURCE: I've got a Minolta model #4050
Yes, it means that something is wrong with the scanner. It may be fixed, it depends what is wrong with it. Is the scanner skewed under the copyboard glass? If so that means that the scanner cables have poped off and they will need to be restrung. It could also be the scanner drive motor or the driver PCB. It may also be that the scanner HP sensor is dirty or is not working correctly. I have worked on these models for years and most of the time it has been a sensor or the cables poped off. There is a jig that makes it easier to restring the cables, but either way it will take time and time is money.... Question is are you willing to put the money in to it?? This model came out around 1995 or so... Good Luck
Nike Merritt
  • 149 Answers
  • Posted on Jan 27, 2010
SOURCE: i have received code C0072? what can I do to
The toner bottle is in wrong, take out the toner bottle and close the front door. wait until the motor stops running or until the copier asks for toner. open the door, the bottle should go in with the hole up.
C0072?
http://www.clubwrx.net/forums/general-maintenance-troubleshooting-accidents/134344685-code2-c0072-yaw-rate-sensor-254-communication-do-i-need-teach-propper-english.html
Error cod c0601
Code C0601 is a problem on scanner, based on my experience, this code comes when the scanner doesn't reach its home position. First try to clear the code opening and closing the front door. If the code still appearing, check for scanner home position sensor, clean it or change it.
C0072 copy error
The error code C0072 deals with the toner hopper. I would remove the toner bottle and close the front door and wait till the copier comes to ready and make a copy, if it works install the toner and see what happens. The problem may be in the toner bottle holder.... There is a "HP" sensor that may be dirty or broken. Good Luck
Minolta ep 5000 error c0072
A C0072 error code deals with the toner bottle. Remove the toner bottle and close the front door and let the machine warm up. Make one copy and install the toner bottle again. The toner holder may have not been in the correct position. If it continues, you may need to call a service person. Good Luck
Error code c0601
Check the exposure lamp drive exposure lamp is the very bright lite that come on under the big glass.
Code C0072
You did not give the model number? So, I'm going to guess, did you just add a new toner? If so remove the new toner bottle and close the door / cover and see if the copier comes to ready? If so, make a copy and when the copy is done install the toner bottle. The error code C0072 deals with the toner hopper motor. If the code will not clear, then you may have a broken gear in the hopper drive unit. Good Luck
Minolta 6100 displays message C0072
Are you certain it is a Minolta 6100? The only 6100 I am aware of is a Magicolor 6100 color printer. My service manual for that model lists no service code C0072.
C0072 is a common Minolta copier code which pertains to the toner add system. I had a service call the other day for C0072 and it was the toner cartridge not fully "locked" in to it's receptacle, so you can start there. Opening and closing the front door on most Minolta's will reset this code.
Good Luck
2helpful
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
5helpful
3answers
7helpful
2answers
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
