Sharp 32C-240 32" TV Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is my sharp code - Sharp 32C-240 32" TV
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Dec 19, 2010
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
To get into the service menu do the following.
Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
After entering to the service manu, goto V-Chip options and Unlock it. You have to reset all V-Chip options after resetting it. OK.
Can anyone help me fix E1-00 on Sharp AR copier?
Sure, but model numbers are important in questions like this. Generic help here.
Error Codes > Sharp > ARM207 > Code E1-00
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E1-00
Code: E1-00 · Description: IMC PWB communication trouble · Causes: IMC PWB-MCU PWB harness abnormality MCU PWB connector disconnection IMC PWB ROM defect/data ...
Sharp AR-M207 Service Manual - Trouble Code List
ManualsLib
https://www.manualslib.com > ... > Service manual
Sharp AR-M207 Manual Online: trouble code list, Details Of Trouble Codes. 1. Trouble Code List Main Sub Code Code E1 00 Imc Pwb Communication Trouble 10 Imc ...
Sharp MX-200 Copier. How to remove E7 from my photocopy machine product Sharp MX-200
E7 is only part of the Error Code ' E7-** '.
Sharp MXB200 - E7 10
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E7 10
Sharp MXB200 ; Code: E7 10 ; Description: Shading trouble (Black correction). The CCD black scan level is abnormal when the shading. ; Causes: Improper connection ...
Sharp MXB200 - Error Code
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E7 11
Code: E7 11 · Description: Shading trouble (White correction). · Causes: Improper connection of the CCD unit flat cable Dirt on the mirror, the lens, and the .
I need to program a Sharp tv DVD combo to the cc'd remote.
Remote Control Codes For Sharp TVs
DirecTutor.com https://www.directutor.com > content > remote-control...
The 4 digit codes for most programmable universal remote controls for Sharp televisions are: 0039; 0093; 0165; 0386; 1004; 1009; 1011; 1025; 1064; 1077; 1078 ...
You've visited this page 2 times. Last visit: 13/02/23
Sharp MX-3640N A3 Color Laser Multifunction Printer. Error service code: C1-14.
Question edited for full 'make model (what it is)'.
Error Codes > Sharp > MX3610N > Code C1-14 - PrintCopy .info
https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
SOLVED: Error code C1-14 - Sharp MX5001N - Fixya
https://www.fixya.com > ... > Sharp
Apr 9, 2019 - Code. C1-14 · Description. Main charger trouble (Color) · Causes. The main charger unit (CMY) is not installed properly. There is an abnormality ...
How to remove error code C1-14 For Sharp MX-2501N - Fixya
Sept 5, 2019
Questions & Answers for: sharp error code c1 14 - Fixya
Nov 16, 2019
SOLVED: Sharp mx 3100n C1-14 error code - Fixya
Dec 12, 2020
Error code C1-14 - Sharp Mx-2310u Color Copy/print/scan
Apr 8, 2013
More results from www.fixya.com Missing: 3640 ‎' Must include: 3640
Sharp MX-2630 Error C1-14 - Copytechnet
https://www.copytechnet.com > ... > Sharp
Apr 27, 2019 - Error Code Sharp MX-2630 Error C1-14. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to ...
Sharp MX2640 error C1-14
Jun 20, 2017
Error Code C1-14 on MX3100N
Jul 23, 2011
MX-6240, 7040 (Polaris) with error code C1-0X ...
Jul 17, 2015
More results from www.copytechnet.com Missing: 3640 ‎' Must include: 3640
Codes erreur SHARP - Sharp Photocopieur
https://www.photocopieur-sharp.com > codes-erreur-sh...
C1. C1 10 MAIN CHARGER TROUBLE (BK). C1 14 MAIN CHARGER TROUBLE (COLOR). C4. C4 00 PTC TROUBLE. E7. E7 01 MFP IMAGE DATA ERROR. E7 03 HDD TROUBLE.
Sharp MX-2310U, MX-3111U (SERV.MAN68) Technical Bulletin
https://servlib.com > Sharp > Printer
MX-2310U, MX-3111U (serv.man68). CCE-1425 MODIFICATION OF TROUBLE CODE C1-10 or C1-14 DUE TO DEFECTIVE MC PWB - Sharp Copying Equipment Technical Bulletin ...
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
3helpful
Code for rca rcr311b remote to sharp tv
96helpful
10answers
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
