KitchenAid KEBC107 Electric Single Oven Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F5EO - KitchenAid KEBC107 Electric Single Oven
  • Anonymous Sep 03, 2019
    Worked on a stove with the code f5e0 we fixed it by open the stove door and holding down the black door pin in the upper right had corner then pushing back on the door lock then close the door fixed. Hope this helps with your problem this is how I fixed ours.
espressonist
Level 3:
  • KitchenAid Master 1,711 Answers
  • Posted on Dec 26, 2010
espressonist
KitchenAid Master
Level 3:
Answers
1711
Questions
Helped
661932
Points
5029
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
Top KitchenAid Ovens Experts
jdthefixer
Sudeep Chatterjee
Sudeep Chatterjee
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
