Sharp Master
- Posted on Dec 22, 2010
Re: Cant sync my universal control what the code
Hello
You just try these codes with your tv. One aboung them will wake up your TV.
NB: Switch OFF and switch ON the Tv each time before a code is tested.
Three digit universal remote codes for Sharp are:-
027 /224 /324 /338 /631/ 637 /737 /825/004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp TV are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
