SOURCE: kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
SOURCE: Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
SOURCE: whirlpool duet dryer - PF error
Here are 2 good ones from very large inventory companies
http://www.apdepot.com/index.asp
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
